bob_bitchen
4 years agoNIOS SDK tools don't see memory region
We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12.
I have a CIV E design in Quartus 21 lite with a NIOS II F.
In platform designer, the NIOS vector selection drop-do...
EBERLAZARE_I_Intel
4 years agoHi,
In that case, for workaround, we could add another EPCQ flash controller in the design as a workaround for the mddr?
With this are you okay, if we proceed to test this?
- bob_bitchen4 years ago
Anything that you can do to get the mddr memory region to show up in the drop-down box in the linker script is a solution - bob_bitchen4 years ago
The SDK could care less about the function of each memory device. Confirmed.
All debugging can be done in a single memory device of R/W configuration.
