bob_bitchen
4 years agoNIOS SDK tools don't see memory region
We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12.
I have a CIV E design in Quartus 21 lite with a NIOS II F.
In platform designer, the NIOS vector selection drop-do...
EBERLAZARE_I_Intel
4 years agoHi,
I am seeing the same as your working output that you attached, I haven't seen the error in the BSP Editor problems from my side,.
My steps was getting your latest design, upgraded to 21.1 lite, then use the sopcinfo for Nios II EDS hello world example, all build are fine.
Could you retry the above and see if the fresh steps could be working or if it still reports error let me know.
bob_bitchen
4 years agoTry using the mddr in the linker script. Or set it to the reset vector in the Nios.
