bob_bitchen
4 years agoNIOS SDK tools don't see memory region
We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12.
I have a CIV E design in Quartus 21 lite with a NIOS II F.
In platform designer, the NIOS vector selection drop-do...
EBERLAZARE_I_Intel
4 years agoHi,
I am seeing the same as your working output that you attached, I haven't seen the error in the BSP Editor problems from my side,.
My steps was getting your latest design, upgraded to 21.1 lite, then use the sopcinfo for Nios II EDS hello world example, all build are fine.
Could you retry the above and see if the fresh steps could be working or if it still reports error let me know.
- bob_bitchen4 years ago
Try using the mddr in the linker script. Or set it to the reset vector in the Nios. - bob_bitchen4 years ago
The original title was "NIOS SDK tools don't see memory region"
So, I gave you a project that doesn't use the memory region because you couldn't get one to compile.
I fixed your problem for you, and now you are supposed to fix the original Intel bug that you introduced prior to Q21.
A month and a half, and you have made zero progress on this.
