19 years agoNIOS program deadlocks
Hello folks, I have an interrupt-based NIOS II program and I'm using the DE2 board. My program works ok sometimes but it seems to deadlock randomly when pushbuttons are pressed or inputs fr...
19 years agoHello, I have a few recommendations.
1. Get your reset address out of volatile memory. - Point it at external flash, or at a pre-initialized "onchip" memory. 2. Get in and out of your ISRs as quickly as possible. - Do a minimal amount of processing to determine the cause of the interrupt. - Push any action off to the main loop of your code or a task (if using an OS). - Follow the example(s) in Count Binary and Board Diagnostics for ISR creation, etc. 3. Are you sure your processor is deadlocked? - It could be that you've set one of your input PIOs to generate level sensitive interrupts....and that level happens to be the default level of the input signal(s). - It could also be that you're (somehow) generating a spurious interrupt. (This would be tricky, unless you're manually enabling an interrupt that does not yet have a handler). Finally, it might help if you post some code illustrating where you suspect the problem(s) to be. Best Regards, - slacker
