21 years agoNios porting in the Altera SLS UP3 Education kit
Hye frndz,
I am getting the problem in porting of the Nios in UP3 Education kit, the problem is that when I am building the system using the Nios cpu and using the sls_ram module for this kit and after that when I am adding the Tri state bridge bus, hat time this bridge take Ram as a slave, which means master port is not connected, and due to this problem it will not generate the system. If I will use flash in the system then it will use flash as a master , but the pin assignments of the flash data bus and conrol signal is the same according to the kit, so, it will not compile the project in Quartus5.0, That's why I am not using flash in my system. Please if any one knows about that kit and knows the solution of the problem, then help me. Thanx1 Reply
May be, you should refer to the "Accessing Memory" tutorial, provided by sls. goto www.slscorp.com/up3support/pages/documents.php.
they also give you a reference design. the design is tailored for the UP3-1C6, so if you use the UP3-1C12 refer to the different pin locations for some of the components. A document explaining the pin-differences between both boards can also be found on this page.
