DDavi59
7 years agoNios peripherals to ARM
Hey everyone,
I am working on Arria V,
I want to know if there is any way to make a BSP that runs with nios II to run with on ARM.
for example,
UART peripheral that runs on nios to make it run on the ARM
i know that there is a FPGA-HPS , but i dont know if it will solve the problem.
Dor
1 Reply
- GHelb
I think you're asking a 'Platform Designer' question, not a 'Board Support Package' question.
A NIOS BSP would not work on an ARM. An ARM BSP would not work on a NIOS.
A BSP for a multi-CPU (ARM & NIOS) is possible.
If you create a custom peripheral for a NIOS it should work on the ARM; they use the same bus.
