JanFranken's avatar
JanFranken
4 years ago
NIOS only boots after nios2-terminal connects
I generate a .jic file and download it into the EPCS64 device. However once the FPGA starts up, the NIOS does not boot. Only when I start the nios2-terminal on the PC does the NIOS boot. Any...
  • JanFranken's avatar
    4 years ago
    Hi Kelly,
    In our case the solution was to remove the JTAG Debug UART and move the stdout/stdin/stderr to a standard UART.
    The NIOS now boots from startup without waiting for the nios-terminal to connect.
    Thank you,
    Jan.
