amildm's avatar
amildm
4 years ago
[NIOS] New CPU Memory HEX file -> should all NIOS system be regenerated?
Hello, When the NIOS Memory HEX file is replaced with a new one -> should all NIOS subsystem be regenerated (new RTL file will be created)? Can not I leave the whole NIOS system untouched and jus...
  • RProesel's avatar
    4 years ago
    You do not have to regenerate the NIOS sub-system if you change the .hex file that you are using to initialize the memory.
    You only have to do 2 steps in Quartus:
    1) Run 'Update Memory Initialization File' in the Processing menu.
    2) Run 'Start Assembler' under 'Start' in the Processing menu.
    This will create a new SOF file using the new .HEX file.
