This is the main.c file of my project , please examine it , LCD still doesnt work ....I am screwed.. :((((
Do I have a problem with this "DALT_USE_LCD_16207" I did not add that.
* "Small Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It requires a STDOUT device in your system's hardware.
* The purpose of this example is to demonstrate the smallest possible Hello
* World application, using the Nios II HAL library. The memory footprint
* of this hosted application is ~332 bytes by default using the standard
* reference design. For a more fully featured Hello World application
* example, see the example titled "Hello World".
* The memory footprint of this example has been reduced by making the
* following changes to the normal "Hello World" example.
* Check in the Nios II Software Developers Manual for a more complete
* description.
* In the SW Application project (small_hello_world):
* - In the C/C++ Build page
* - Set the Optimization Level to -Os
* In System Library project (small_hello_world_syslib):
* - Define the preprocessor option ALT_NO_INSTRUCTION_EMULATION
* This removes software exception handling, which means that you cannot
* run code compiled for Nios II cpu with a hardware multiplier on a core
* without a the multiply unit. Check the Nios II Software Developers
* Manual for more details.
* - In the System Library page:
* - Set Periodic system timer and Timestamp timer to none
* This prevents the automatic inclusion of the timer driver.
* - Set Max file descriptors to 4
* This reduces the size of the file handle pool.
* - Check Main function does not exit
* - Uncheck Clean exit (flush buffers)
* This removes the unneeded call to exit when main returns, since it
* won't.
* - Check Don't use C++
* This builds without the C++ support code.
* - Check Small C library
* This uses a reduced functionality C library, which lacks
* support for buffering, file IO, floating point and getch(), etc.
* Check the Nios II Software Developers Manual for a complete list.
* - Check Reduced device drivers
* This uses reduced functionality drivers if they're available. For the
* standard design this means you get polled UART and JTAG UART drivers,
* no support for the LCD driver and you lose the ability to program
* CFI compliant flash devices.
* - Check Access device drivers directly
* This bypasses the device file system to access device drivers directly.
* This eliminates the space required for the device file system services.
* It also provides a HAL version of libc services that access the drivers
* directly, further reducing space. Only a limited number of libc
* functions are available in this configuration.
* - Use ALT versions of stdio routines:
* Function Description
* alt_printf Only supports %s, %x, and %c ( < 1 Kbyte)
* alt_putstr Smaller overhead than puts with direct drivers
* Note this function doesn't add a newline.
* alt_putchar Smaller overhead than putchar with direct drivers
* alt_getchar Smaller overhead than getchar with direct drivers
# include "sys/alt_stdio.h"
# include <unistd.h>
# include "system.h"
# include "altera_avalon_pio_regs.h"
# include <stdio.h>
# include "alt_types.h"
# include "altera_avalon_lcd_16207_regs.h"
# include "altera_avalon_lcd_16207.h"
# define LCD_WR_COMMAND_REG 0
# define LCD_WR_DATA_REG 2
void lcd_init(void);
void lcd_test(void);
int main()
alt_putstr("Hello from Nios II!\n");
usleep(15000); /* Wait for more than 15 ms before init */
lcd_init();
lcd_test();
while (1);
return 0;
void lcd_init(void)
/* Set function code four times -- 8-bit, 2 line, 5x7 mode */
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x38);
usleep(4100); /* Wait for more than 4.1 ms */
usleep(100); /* Wait for more than 100 us */
usleep(5000); /* Wait for more than 100 us */
/* Set Display to OFF*/
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x08);
usleep(100);
/* Set Display to ON */
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x0C);
usleep(100);
/* Set Entry Mode -- Cursor increment, display doesn't shift */
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x06);
usleep(100);
/* Set the Cursor to the home position */
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x02);
usleep(2000);
/* Display clear */
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE,0x01);
usleep(2000);
void lcd_test(void)
int i;
char message[17] = "Hello World... ";
char done[15] = "Done! ";
/* Write a simple message on the first line. */
for(i = 0; i < 16; i++)
IOWR_ALTERA_AVALON_LCD_16207_DATA(LCD_BASE,message
usleep(100);
/* count along the bottom row */
/* set address */
iowr_altera_avalon_lcd_16207_command(lcd_base,0xc0);
usleep(1000);
/* display count */
for (i = 0; i < 10; i++)
iowr_altera_avalon_lcd_16207_data(lcd_base,(char)(i+0x30) );
usleep(500000); /* wait 0.5 sec */
/* write "done!" message on first line. */
/* set address */
iowr_altera_avalon_lcd_16207_command(lcd_base,0x80);
usleep(1000);
/* write data */
for(i = 0; i < 14; i++)
iowr_altera_avalon_lcd_16207_data(lcd_base,done);
usleep(100);
