11 years agoNIOS is constantly reading from instruction memory and reading/writing to data memory
Hello all, I am still working on my first NIOS design and am having troubles with the instruction/data memory access. Below is a schematic of the NIOS and its peripherals. The NIOS is connected...
11 years ago --- Quote Start --- If this is your first NIOS design, I highly recommend that you build the design in Qsys. Start with an online lab that can get you started. Try this class: http://wl.altera.com/education/training/courses/oniihw - there is lab that takes step by step on how to build up a Qsys system with a NIOS and peripherals and then you can compile Hello World SW. Then expand from there. Best of luck! --- Quote End --- I have gone through a few different tutorials. I seem to have everything setup in qsys. I believe my problem is coming from the eclipse software build tools. I have not found a whole lot of information there.
