22 years agonios interface with fifo
How can I interface nios to the fifo outside the nios?
21 years agoHi Narab1,
Yeah, I got it working. You can tell by all the blood http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif On NiosII: "Create New Component" a port with a IRQ signal and others. (my class.ptf follows) Set the IRQ very high priority (like 0 or 1) If you have any other ISR's turn on nested interrupts, or raise the size of the fifo above the IRQ point until you're ISR gets called in time. Good Luck! Ken Here is my FIFO spec. NFIFO : scfifo WITH ( INTENDED_DEVICE_FAMILY = "Cyclone", (works on Stratix too) LPM_WIDTH = 36, LPM_NUMWORDS = 512, LPM_WIDTHU = 9, LPM_TYPE = "scfifo", LPM_SHOWAHEAD = "ON", OVERFLOW_CHECKING = "OFF", UNDERFLOW_CHECKING = "OFF", USE_EAB = "ON", ADD_RAM_OUTPUT_REGISTER = "ON" ); Hook the used[] bits up to an and gate to create an appropriate IRQ into the NiosII. Register your ISR to dma from the fifo (hooked into your Component as well) into memory or whatever. Here is my Component's class.ptf: # # This class.ptf file built by Component Editor# 2005.01.25.15:22:30# # DO NOT MODIFY THIS FILE# If you hand-modify this file you will likely# interfere with Component Editor's ability to# read and edit it. And then Component Editor# will overwrite your changes anyway. So, for# the very best results, just relax and# DO NOT MODIFY THIS FILE# CLASS scan_in { MODULE_DEFAULTS { class = "scan_in"; class_version = "1.0"; SYSTEM_BUILDER_INFO { Instantiate_In_System_Module = "0"; } PORT_WIRING { } SIMULATION { DISPLAY { } } SLAVE SCAN_IN { SYSTEM_BUILDER_INFO { Bus_Type = "avalon"; Address_Width = "2"; Address_Alignment = "dynamic"; Data_Width = "32"; Has_Base_Address = "1"; Has_IRQ = "1"; Setup_Time = "0cycles"; Hold_Time = "0cycles"; Read_Wait_States = "1cycles"; Write_Wait_States = "1cycles"; Read_Latency = "0"; Max_Pending_Read_Transactions = "1"; Is_Printable_Device = "0"; Is_Memory_Device = "1"; } PORT_WIRING { PORT address { width = "2"; width_expression = ""; direction = "input"; type = "address"; } PORT RE { width = "1"; width_expression = ""; direction = "input"; type = "read"; } PORT readdata { width = "32"; width_expression = ""; direction = "output"; type = "readdata"; } PORT dataIRQ { width = "1"; width_expression = ""; direction = "output"; type = "irq"; } PORT CS { width = "1"; width_expression = ""; direction = "input"; type = "chipselect"; } } COMPONENT_BUILDER { AVS_SETTINGS { Setup_Value = "0"; Read_Wait_Value = "1"; Write_Wait_Value = "1"; Hold_Value = "0"; Timing_Units = "cycles"; Read_Latency_Value = "0"; Max_Pending_Read_Transactions_Value = "1"; Address_Alignment = "dynamic"; Is_Printable_Device = "0"; Is_Memory_Device = "1"; external_wait = "0"; } } } } USER_INTERFACE { USER_LABELS { name = "SCAN_IN"; technology = "User Logic"; } WIZARD_UI the_wizard_ui { title = "SCAN_IN - {{ $MOD }}"; CONTEXT { H = "WIZARD_SCRIPT_ARGUMENTS/hdl_parameters"; M = ""; SBI_SCAN_IN = "SLAVE SCAN_IN/SYSTEM_BUILDER_INFO"; } PAGES main { PAGE 1 { align = "left"; title = "scan_in Settings"; layout = "vertical"; TEXT { title = "Built on: 2005.01.25.15:22:30"; } TEXT { title = "Class name: scan_in"; } TEXT { title = "Component name: SCAN_IN"; } TEXT { title = "Component Group: User Logic"; } } } } } CB_GENERATOR { top_module_name = ""; emit_system_h = "0"; HDL_FILES { } } COMPONENT_BUILDER { CACHED_HDL_INFO { # cached hdl info, emitted by cbGuinevereApp.CBFrameRealtime.getDocumentCachedHDLInfoSection:130 # used only by Component Builder } HDL_PARAMETERS { # generated by cbDocument.CBDocument.getParameterContainer:348 # used only by Component Editor } SW_FILES { } built_on = "2005.01.25.15:22:30"; } ASSOCIATED_FILES { Add_Program = "the_wizard_ui"; Edit_Program = "the_wizard_ui"; Generator_Program = "cb_generator.pl"; } }
