16 years agoNios instability
Hello, I'm using nios II processor with a high_res_timer for different test before continuing my project. The test i'm trying to do is to generate on a pin a square frequency with a 400µs period...
16 years ago --- Quote Start --- for information, i get a better stability now by changing some settings, now I use a nios II/f with a 125MHz --- Quote End --- I have not enough experience to suggest you which core is better in your case. Surely /f is better for complex code since relies on features like cache and branch prediction. On the other hand, it uses much more LEs so I suppose it possibly needs to run at a slight lower frequency than /e. --- Quote Start --- do you think it will be enough for the application i told you above --- Quote End --- As I told before, it could be enough, but your application must be devoted only and totally to poll the timer in order to get the exact switching time. That means your Nios can't do any other task. IMHO it's a very inefficient way to use a processor! --- Quote Start --- does someone know where i can get the following information : what is the maximum frequency for a nios II/f with the cyclone III ep3c120f780c7n --- Quote End --- I also tried to find a specification about nios fmax but never found a clear one. From what I understood it depends from your project timings. I pushed without problems a Nios II/f to 100MHz; I think you can go beyond if you are smart and if you know how to work with Quartus timing constraints. Cris
