16 years agoNios instability
Hello, I'm using nios II processor with a high_res_timer for different test before continuing my project. The test i'm trying to do is to generate on a pin a square frequency with a 400µs period...
16 years agofor information, i get a better stability now by changing some settings, now I use a nios II/f with a 125MHz, do you think it will be enough for the application i told you above SEILASER
does someone know where i can get the following information : what is the maximum frequency for a nios II/f with the cyclone III ep3c120f780c7n, i found around 165MHz but for another cyclone III thanks in advance for your help
