NIOS II/f altera_avalon_i2c, possible BUG in HAL
Thank You report this.
I could SCL drive 400k.
but Is it collect which using I2C Master API ?
I wrote cfg speed set secont argument "400000".
But I couldn't drive 400k.
So Google it and got this report.
Why Intel doen't fix it.
Anyway. Thank you.
Yes, this appears to be a bug in the HAL ... still ... after at least six years. I'm running an I2C bus on an Agilex part, and we added a peripheral that could run at 400kHz; we had previously been running the I2C bus at 200kHz without issue, though the generated clock looked like crap - duty cycle was nowhere near 50%.
In the file drivers/src/intel_avalon_i2c.h we changed:
//#define ALT_AVALON_I2C_DIFF_LCNT_HCNT 60
#define ALT_AVALON_I2C_DIFF_LCNT_HCNT 30
System runs fine at 100kHz, 200kHz and 400kHz now.
Edit:
Had better results dropping the ALT_AVALON_I2C_DIFF_LCNT_HCNT value to 10. Low-half of the SCL clock is right around 1us; high-half is nominally 1.4us.
Scope traces are attached. One shows the system not-running with the way-too-skinny SCL clock - ALT_AVALON_I2C_DIFF_LCNT_HCNT set to 50. The other (which works) has the parameter set to 10.
