15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoIt finally worked!
I used TimeQuest Wizard to add the lines that Thormodo cited and added the reset pin to the PLL. It worked like a charm :) As for the questions I asked, I found that the address is defined in the image generated. I believe that it is a logical address rather than a physical one, but not sure yet. It didn't uncompress the linux image, but I was expecting it due to low memory availability. Now I'll fight the uClinux-dist rather than the Quartus II. Thank you all again for your patience. As soon as I get everything to work, I will write a short tutorial and maybe an entry to the wiki. Best regards Bruno
