15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoclock definitions and timing constraints are written in .sdc files when you use Timequest as a timing analyser. Have a look at the reference design and look for one or several .sdc files. Hopefully it will contain all the timing definitions that you need for your board. Copy the files in your project folder, add them to your project and recompile. Look for critical warnings such as "timing requirements not met". If you have those then you have a timing problem.
