15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoI'm not at sure why the SDRAM clock has to be 'early' - since the simple timing analysis then gives errors. The errors can be removed by changing the skew (I increased it a bit - more -ve) - but then the sdram didn't work!
IIRC the cyclone dev board needed about -3.4ns, I suspect this is actually independant of the clock speed!
