15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agoDid you declare your clock in an sdc file for timequest and did you constrain your inputs/outputs? 100MHz should be reachable.
I don't have any experience on that board with the sdram so I can't help you there, but it could be easier to start with a design example that works and modify it to suit your needs instead of starting from scratch.
