15 years agoNios II won't work after uploaded to the board
Greetings, I have a Nios II design that i've built from scratch, mainly following instructions on the book Rapid Prototyping of Digital System. It compiles without errors (but several warnin...
15 years agocheck that you provide a valid clock to your CPU and that you meet timing requirements.
Check also the polarity of the reset signal. IIRC the reset input on a SOPC component is active low (which is indicated by a "_n" at the end of the signal name) and I don't remember what is the polarity of a push button input on that kit.
