13 years agoNios II with on-chip Dual port ram between Nios and External DSP
Hello, I'd like to implement a dual port ram using on chip memory, with one side connected to the Avalon bus and other connected to an external DSP. Not sure where to get started; I can not se...
12 years ago --- Quote Start --- Yes, its correct! Did You manage to connect External DSP to the exported second (s1) port of the dual port RAM? If Yes , the please answer: 1). why Write signal is present, but the Read signal is missing on the exported second (s1) port of the dual port RAM? 2). Is Write really is WriteEnable? 3). how to use clken ( clock enable ) on the exported second (s1) port of the dual port RAM? --- Quote End --- Did you get an answer to this? I have the same question. Since there is no read signal exported the write must be a write/read_n or write high read low level? Is clken or chipselect used as a data strobe? Are all signals active high? clken, chipselect, write? byteenable is active high so if you specify byteenable as all ones 4'b1111 for 4 byte 32 bit interface you are writing all 32 bits in one write cycle.
