15 years agoNIOS II Tutorial Problems
Hi, I did some searching on my problem but could not track down an answer hence the need to post here, I have been working through the Nios II Hardware Development tutorial and have run into tw...
15 years agoHI,
I am sorry for not being available.I got busy with other work. Yes one has to make sure that all the files you run have admin rights , in quartus or in sopc builder or in eclipse.When you in the IDE of eclipse you cannot delete the metadata.And once metadata is deleted you have to create new template and redo the whole proceedure. I hope it helps!!
