15 years agoNIOS II Tutorial Problems
Hi, I did some searching on my problem but could not track down an answer hence the need to post here, I have been working through the Nios II Hardware Development tutorial and have run into tw...
15 years agoThe first issue you described could be caused by the directory path of your project. I've seen the same issue and I believe in my case it was a directory naming issue. If that isn't the issue ensure the file permissions are set correctly for your project directory.
