ltazz1
6 years agoNIOS II toolchain roadmap / Eclipse broken
Any new about the NIOS II toolchain roadmap? In Q19.1 Std Eclipse is completely broken with Windows 10, there are a lot of video artifacts during debug that make the screen unreadable. I would like ...
ltazz1
6 years agoI found another bug, Eclipse is not detecting the System ID, a 0 or "Not found" is displayed when analyzing the target connection (see attached picture).
Using system-console I can read the right data at the system id MM address
Using Nios II Hardware v2 (beta) configuration seem to fix the issue (only some times). but this is very bad!
Today I even found another bug with TimeQuest. If there is an error in the SDC file and you Create the netlist from the GUI the first time you get a message, the second time everything crash!
I'm experiencing a lot of bugs with this new Q19.1 std, should Intel hire me to improve Quartus?
