14 years agoNIOS II SBT Configuration with EPCS Controller
Hi All, I have a basic NIOS II system with a EPCS Controller used for booting. I have successfully flashed the EPCS device and on power-up the FPGA configures and the NIOS boots. However, ...
14 years agoThis is starting to sounds a bit more complicated than I'd hoped!
I suppose I'd imagined that given how seemless the approach to booting from EPCS had been (good support and documentation), I'd imagined that the BST would have been 'setup' to deal with that approach. The easiest path at the moment is probably to develop with the NIOS reset vector set to the base of the on chip memory, then change it over to the EPCS controller when I want to flash the EPCS. Out of interest, what is the inconsistency between paddr and vaddr a sign of? I've certainly not done anything deliberate to make it that way!Sections:
Idx Name Size VMA LMA File off Algn
0 .entry 00000020 00008800 00008800 00004800 2**5
CONTENTS, ALLOC, LOAD, READONLY, CODE
1 .exceptions 00000194 00004020 00004020 00001020 2**2
2 .text 00002c80 000041b4 000041b4 000011b4 2**2
3 .rodata 00000078 00006e34 00006e34 00003e34 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
4 .rwdata 000002e0 00006eac 0000718c 00003eac 2**2
CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA
5 .bss 0000011c 0000746c 0000746c 0000446c 2**2
ALLOC, SMALL_DATA
