14 years agoNIOS II SBT Configuration with EPCS Controller
Hi All, I have a basic NIOS II system with a EPCS Controller used for booting. I have successfully flashed the EPCS device and on power-up the FPGA configures and the NIOS boots. However, ...
14 years agoHi DSL,
Over the weekend I had a similar thought. It looks like a simple reset branch is 'trying' to be placed in the EPCS controller memory location. Some select parts from objdumpProgram Header:
LOAD off 0x00001020 vaddr 0x00004020 paddr 0x00004020 align 2**12
filesz 0x00002e8c memsz 0x00002e8c flags r-x
LOAD off 0x00003eac vaddr 0x00006eac paddr 0x0000718c align 2**12
filesz 0x000002e0 memsz 0x000002e0 flags rw-
LOAD off 0x0000446c vaddr 0x0000746c paddr 0x0000746c align 2**12
filesz 0x00000000 memsz 0x0000011c flags rw-
LOAD off 0x00004800 vaddr 0x00008800 paddr 0x00008800 align 2**12
filesz 0x00000020 memsz 0x00000020 flags r-x Sections:
Idx Name Size VMA LMA File off Algn
0 .entry 00000020 00008800 00008800 00004800 2**5
CONTENTS, ALLOC, LOAD, READONLY, CODE Disassembly of section .entry:
00008800 <__reset>:
8800: 00400034 movhi at,0
8804: 08506d14 ori at,at,16820
8808: 0800683a jmp at All this does make sense as to use the EPCS Controller Boot Loader you need to set the NIOS reset vector to the base address of the EPCS Controller. However, this of course makes things awkward when trying to load a binary over JTAG from the BST. Is there anything I can do to make this work? Thanks again Andy
