20 years agoNIOS II reset
Dear everybody, My goal is to reset NIOS II. NIOS II owns the reset_n input and I drive this input with a signal ON-OFF-ON where the OFF state lasts 20 us with the clk signal always present...
20 years ago --- Quote Start --- originally posted by jdhar@Apr 7 2006, 04:46 PM the best reset method i have found is simply to and together the lock outputs from the plls. you can even specify the plls to have a delay on the lock output (which i use). and those together with your resetn signal (cleanly debounced of course), and you should be good to go.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14135)
--- quote end ---
--- Quote End --- Thanks JDHAR. But, wouldn't this only have an effect during power-up? I am not resetting the PLL's, so I would expect they would be running fine, and the lock output would be a constant '1'. Should I reset the PLL's? I typically don't even select the option to have an 'areset' input going to them.
