20 years agoNIOS II reset
Dear everybody, My goal is to reset NIOS II. NIOS II owns the reset_n input and I drive this input with a signal ON-OFF-ON where the OFF state lasts 20 us with the clk signal always present...
20 years ago --- Quote Start --- originally posted by alessandro@Mar 2 2006, 10:28 AM dear everybody,
my goal is to reset nios ii. nios ii owns the reset_n input and i drive this
input with a signal on-off-on where the off state lasts 20 us with the clk
what happens is that nios ii makes a reset because the software crashes, but
it never exits from this state when the reset_n input goes high again. i have to
make a fpga configuration by pulling down nconfig in order nios ii runs again.
where am i wrong ?
best regards
/alessandro
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13067)
--- quote end ---
--- Quote End --- perhaps 20us is not enough, I don't know, I use a avalon timer and simple let it run into a watchdog reset to reset the cpu. avalon timer "timer_wd" - PresetConfiguration (Custom) - fixed period 3 sec - enabled timeout pulse (1clock wide) - enabled system reset on timeout if I want to reset the whole chip I can enable an "and gate" to let the timeout pulse from the watchdog timer trigger the reconfig request output.
