13 years agoNIOS II memory writes failing - values being input at wrong addresses (I2C opencore)
Hi, I'm trying to integrate an I2C core from opencores to my Cyclone IV device. Apparently the version I'm using should just drop into the SOPC and work after being wired to some outputs (alter...
13 years agoAh! I'm very sorry I did not know that multiple triggers have to assert simultaneously. With that change I do get a trigger on write. Thank you very much for that lesson! It's been working for me up to now by shear luck!
On the memory write problem, I havn't gotten any further. I have been using the VHDL version of the core as the rest of my code is VHDL so I wanted to keep in VHDL for continuity. However, I decided to throw in the towel for now and use the Verilog version which worked almost straight away when I wired it up. My plan is to implement my application fully with the Verilog core and then maybe come back to the VHDL to try to debug. Thanks a million for your time.
