13 years agoNIOS II memory writes failing - values being input at wrong addresses (I2C opencore)
Hi, I'm trying to integrate an I2C core from opencores to my Cyclone IV device. Apparently the version I'm using should just drop into the SOPC and work after being wired to some outputs (alter...
13 years agoThanks for your reply.
I've set up signal tap to try trigger on write (Compiling now). I'm using: # define IOWR(base,offset,value) __builtin_stwio ((unsigned int*)BASE + OFFSET, (DATA)); IOWR(I2C_MASTER_BASE, 5, 0x1D); to write to the registers which I think is working because it works fine for some registers and with simple PIO tasks. I am confident that 0x9866160 is the correct address as it is taken from the SOPC builder and based on the fact that when I initiate values into the registers in the VHDL I can see them at this address in the debug window. I am sure the FPGA is configured in the correct order as I've been working on it for several days now so it's been programmed many times now. However, I am re-compiling right now so will make 100% sure the order is correct. Thanks for your time, i'll update the situation when I see if I can trigger on write.
