22 years agoNios II max clock speed
Hi nios gurus, Does anyone know if the nios II is capable of running in the 123MHz range? I am using a nios I design with a cyclone dev kit currently and would like to step up to nios II. I'...
22 years agoIf you want the fastest clock frequency and don't have high performance requirements, use the Nios II/e core since it is able
to achieve over 180 MHz in Altera's fastest Stratix I devices (e.g. Stratix I, 1S40, C5 part). Even though you are using Cyclone and maybe a slower speed grade, this should give you enough headroom in Fmax. BTW, on the fastest Stratix I device, Nios II/f (highest performance) and Nios II/s (medium performance) can achieve up to 148 MHz for a small system with small caches. The hard limit on Stratix I devices is the hardware multiplier which runs up to 148 MHz. On fast Cyclone I devices, 125 MHz is about the fastest you'll see. The fastest Nios I achieves about 125 MHz on the fastest Stratix I devices so using Nios II will help you achieve Fmax goals. To get these frequencies, make sure you are using a recent version of Quartus, optimize for speed (instead of area), and turn on all the physical synthesis options.
