ntahoturi5922
4 years agoNIOS II IDE error
If anyone has gotten such error, Can you let me know how you fixed it?
Much appreciated!!!!
ShengN_altera
4 years agoHi,
Need a system timer in your SOPC project.
- In SOPC builder, you'll find the timer in the library: Peripherals > Interval timer
- Set a timeout period of 10ms and select the Simple periodic interrupt preset.
- Then regenerate your SOPC system and recompile Quartus project.
- Make sure that the system clock inside OS_CFG.h file points to 10ms timing.
- I don't remember if the bsp settings are automatically adjusted. If not you may need to update them and select the timer you just created as system timer before recompiling the software.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
