CLope30
7 years agoNIOS II hard fault due to pulse interrupt
I have a NIOS II system and I was sending a pulse interrupt (of 16 clock cycles). The NIOS was going to an exception handler instead of the ISR. I changed the pulse to a level signal and added a clear signal controlled by a PIO bit and now the ISR is executed.
The question is, why the hard fault? I would expect that the NIOS would miss the pulse and do nothing.
Carlos
- RInfo1
Also waiting for answer.
- Ahmed_H_Intel1
Hi, The interrupt will push the NIOS II to go to the exception handler and usual. Please check the following document for more info. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii52006.pdf Regards,
