10 years agoNIOS II Gen2 Hardware Breakpoints broken?
It appears that there may be an issue with NIOS II Gen2 Hardware Breakpoints. On a MAX10 device, I have my program text in UFM, and Hardware Breakpoints set to 4 (using Quartus Prime 5.1.1). H...
10 years agoTom,
Can you set the data triggers to 4 as well? Please re-generate RTL and recompile in Quartus. The issue was that the debugger reads the data triggers value to determine the hardware breakpoints. Previously, for the classic/legacy core the debug level 2 and above have the same hardware breakpoints and data triggers.
