10 years agoNIOS II gen 2 not starting when code compiled with O0 optimization
Hi, My code simply does not run if in the BSP settings I leave the default O0 compiler optimization. With O1 and Os it works I have tried. The code starts like this: *leds = 0xFF;...
10 years agoYes there is more than enough memory. I resolved this by starting a new project from scratch and copy-pasting the vhdl and the c code.
It is a configuration problem that messes up the project either when you copy it from somewhere (because of absolute paths) or when you upgrade the project from a previous version of Quartus. I am not sure which one - i don't plan to spend more time analyzing this. What I can confirm is: 1. Problem dissapears when: starting a new project from scratch - new Quartus project, rebuilding the system in qsys, new project in SBT. VHDL code was copy pasted and so were the c code files. 2. Problem dissapears even if I use the nios system as it was in the project that had the problem (hence the problem is not in Qsys system) 3. Problem remains if I recreate the SBT from scratch in the Quartus project with the problem. (of course copy the c-code files) I really don't like this kind of behaviour of the software - unfortunately altera is not the only having such problems, in fact I would expect any complicated toolchain to have this kind of issues.
