10 years agoNIOS II gen 2 not starting when code compiled with O0 optimization
Hi, My code simply does not run if in the BSP settings I leave the default O0 compiler optimization. With O1 and Os it works I have tried. The code starts like this: *leds = 0xFF;...
10 years agoHave you checked whether your memory is sufficient for your code? Can you try to increase your onchip-memory? I assume you are running from onchip-memory.
