nios ii flash programmer
Have you tried to program your flash using Quartus Programmer and PFL.
You can refer to below for PFL IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
yeah i tried with pfl ,
actually i initilized onchip memory with hex file and i genreted the sof file .
and that sof file is converted into pof file .
that is wroking fine on power on .it s stored in the flash .
but when i add tristate controller and conduit bridge its not working .i tried all the methods explained in edhandbook.
when i add sof and hex file separately to generate the pof and i programmed its not working.
i want to know the pof file content and when converted to .hexout there is so much data .i want to know the addresss in which that data of pof is storing in cfi flash locations.
