nios ii flash programmer
Hello
Can we access or flashing Directly from FPGA if we doesn't have CPLD in our Board?
- praveenkumar5 years ago
No,we didnt have cpld in our board ,we normally flashing through jtag in quartus prorammer by convertiong sof to pof . it is running fine after power on . but in final level after system integration it's not possible to flash using jatg .
so we have to download it through uart by writing the file flash manually from 0x20000 .
Is it workout .
and also problem with generic tristate conroller behaving like explained below
i designed in the qsys and also while i writing to flash by following the datasheet procedure .
ox4089 if i am writing this 16 bit data in some 0x0 location
and while i am reading the location 0x0 its showing 0x89 and 0x1 location its showing 0x40.
its showing lsb in 0x0 location and MSb in 0x1 location.
through code its reading some cfi table locations according to datasheet.
so i think i correctley designed in qsys. and none of the above problems are solved .
please answer these two questions.
yeah we can access the flash through fpga without cpld in quartus programmer and also with nios ii flash programmer .after
compilation stage goto
programmer section and attach or add your fpga device and browse for .sof file if u want to program to flash
right click on fpga device and u can find attach flash option .
u can choose which flash u used in your card .
and programm it.
