15 years agoNios II flash programmer problem
I have a problem with the Nios II flash programmer. I created a project with the Quartus 10 SOPC builder starting from the reference design, triple-speed Ethernet. With Quartus 10 could program the nios. Moving to version 11 I have the following problem with the NIOS II flash programmer Erase failed at offset 800000 Leaving target processor paused Error code: 1 for command ... I'm using the STRATIX IV - EP4SGX230KF40C2 Thanks1 Reply
11.0的USB-Blaster驱动有问题,换以前的版本即可。
The driver of usb-blaster v11.0 can not work normally, try an old version to fix the problem.
