13 years agoNios II exception handler
Hi, I'm using Nios II and experiencing some strange behaviors. 1. Sometimes the system gets stuck. 2. The system resets. 3. In debug mode - the software get stuck after going to a trap. ...
13 years agoYou won't find an easy solution to that one. Some options:
1) Add software to verify that x[3] doesn't change. 2) Use a mmu and make x[2] be the end of a memory page, and make sure the following page is never allocated. 3) Use on-chip debugger facilities to trap on writes to specific locations (only a few traps will ever be supported, not sure the nios has any). 4) Use signaltap to detect writes to x[3]. 5) Wrap all the array accesses in functions and verifu=y the index. 6) Write the code carefully!
