OKris1
6 years agoNIOS II don't boot up after reset
Hi. I have a Cyclone III FPGA Starter Board bought back in 2010. I have started on some NIOS II applications to leanr the C code firmware part of the FPGA. I have downloaded niosii-ethenernet standa...
EricMunYew_C_Intel
6 years agoHi, Oystein
You can refer to below page 219 - 350 for Nios boot (from external flash) method.
For Cyclone III, you can use Quartus 15.
In the above link, you can follow the method to generate .hex (with boot copier) for your flash using mem_init_generate. Your reset vector and exception vector are pointing to external flash, and follow the correct method in BSP linker.
Eric
