11 years agonios ii doesn't run hello world (or sometimes not correctly)
Hi Guys, i have a problem with the niosii. I use a Altera Cyclone IV EP4CE22E22C8N on a selfmade board. The board now only contains a 60MHz Clock, the fpga and a sdram. The Reset and exception...
11 years ago --- Quote Start --- I have seen similar issue with de0-nano that the hello world does not run properly. It was due to timing issue with the SDRAM. --- Quote End --- I agree with mikedsouze - SDRAM timing is probably the problem. Build a NIOS that runs from on-chip memory. Get the memory test running RK
