11 years agonios ii doesn't run hello world (or sometimes not correctly)
Hi Guys, i have a problem with the niosii. I use a Altera Cyclone IV EP4CE22E22C8N on a selfmade board. The board now only contains a 60MHz Clock, the fpga and a sdram. The Reset and exception...
11 years agoDid you connect the debug reset request to the CPU and all its peripherals?
When you are downloading the elf content via nios2-download command, do include -r flag to reset your system.
