11 years agoNios II DDR SDRAM read latency
Hi, I’m trying to optimize RAM access from Nios II. when reading 10’000 successive words from ram using iord in a for-loop, it takes 25 clock cycles per read (without loop overhead). To...
11 years agoHow many clocks does your loop take without the IORD() ?
How many does it take if you do the IORD() twice in each loop (with nothing in between)? Or try using signaltap to trace the actual cycle. I've a note that says most reads from SDRAM took 16 clocks, but some took 12. Writes were more interesting: single writes took 2 clocks, but the third took much longer. I assume a two stage 'pipeline' of some sort. DDR will only be worse than SDRAM.
