11 years agoNios II DDR SDRAM read latency
Hi, I’m trying to optimize RAM access from Nios II. when reading 10’000 successive words from ram using iord in a for-loop, it takes 25 clock cycles per read (without loop overhead). To...
11 years agoHi Simon,
I would suggest using memcpy instead of IORD. You could read data in blocks reducing considerably the latency involved. I understand that you are using single words but it would be more efficient to load a block of data from DDR, store it in an array and use each word from this block. Best regards, Thiago
