20 years agoNIOS-II Cyclone II devboard timer problem
Hi all, my problem is with Cyclone II running NIOS-II. After creating a timer in SOPC builder and implementing it to my design, I am trying to generate periodic interrupts with some desired period...
20 years ago --- Quote End --- Hardware, definitely. If you want a free-running, steady clock signal, you just need a peripheral to generate it. Try this Verilog: ... --- Quote End --- Hi Mike, thanks a lot for your advice. I was trying to follow the steps you showed me in previous post. Everything went fine until I started the compilation of my project in Quartus II. Here, in Pre-compilation (or Analysis) phase I get the following error: "" Error: Node instance "the_ClockGenerator" instantiates undefined entity "ClockGenerator" "" Clicking this message takes me into the Verilog design file of the ClockGenerator module. I tried to browse the forum to find any hint, but couldn't find anything useful. Do you have any idea how to resolve this problem?
