20 years agoNIOS-II Cyclone II devboard timer problem
Hi all, my problem is with Cyclone II running NIOS-II. After creating a timer in SOPC builder and implementing it to my design, I am trying to generate periodic interrupts with some desired period...
20 years ago --- Quote Start --- originally posted by cableguy@Oct 27 2005, 03:54 AM what would you suggest to me to create such a signal, either by software or hardware, so higher frequency can be reached?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10623)
--- quote end ---
--- Quote End --- Hardware, definitely. If you want a free-running, steady clock signal, you just need a peripheral to generate it. Try this Verilog:
module ClockGenerator
input clock,
input reset,
input chipselect,
input write,
input writedata,
output reg clockout
reg count, limit;
always @(posedge clock, posedge reset)
if(reset) begin
count <= 0;
limit<= 0;
clockout <= 0;
end
else begin
if(limit == 0)
clockout <= 0;
else if(count == limit) begin
count <= 0;
clockout <= ~clockout;
end
else
count <= count + 1;
if(chipselect && write)
limit<= writedata;
end
endmodule Take that, use SOPC Builder to make it into a component (set the pin types to the same as their names, except "clockout" should be "export" type), and add it to your system. Let's say you name it "clock_gen". When you generate the system, you'll have a clockout_from_the_clock_gen (or clockout_to_the_clock_gen? I can never remember) pin that you hook up to your ADC's clock. In software, you just have to# include "system.h" and <io.h>, then you can use "IOWR(CLOCK_GEN_BASE, 0, x)" to change the divisor to x (where output clock frequency = sysclock / (2 * (x + 1)) ), and "IOWR(CLOCK_GEN_BASE, 0, 0)" to turn it off.
