MMuth8
6 years agoNIOS II console is not printing after adding QSPI IP in qsys
Hi, In the woking ethernet example, i have added Altera QUAD SPI controller IP (N25Q512A83GSF40F), after adding this IP NIOS console window is not printing. Is there any eclipse settings specific to...
Isaac_V_Intel
Contributor
6 years agoHello Mahalakshmi,
Can you please make sure that the Makefile is been created correctly and up to date?
you can do the following to make sure the Makefileis up to date:
1- Open the BSP project folder
2- Right click the Makefile>> Delete
3- Open the NIOS II Command Shill
4- Write the following command:
cd <...../project_bsp>
nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/>
5- Build your project again.
Let me know if it works.
Isaac.
