NIOS II Build Tools 19.1 now fail to build
Hi @SHard2,
Good day and hope you are doing well, thank you for your patients.
Can you please try the below steps:
- Dividing workspace project and source software directories. It must be different directories inside common project directory.
- Use "New'"--> "NIOS II Application and BSP from template" for generation of new BSP project structure. ("New" --> "NIOS II Board support package", will cause some error as below)
Example error:
Executing: wsl;nios2-bsp hal . ../../qsys_system.sopcinfo
--cpu-name nios2_gen2_0
(D:\Temp\axie_system_controller_restored\software\qsys_bsp)
/bin/bash: -c: line 0: syntax error near unexpected token `;'
/bin/bash: -c: line 0: `;nios2-bsp hal .
../../qsys_system.sopcinfo --cpu-name nios2_gen2_0'
Just curious, what are the window version that you are using?
Is there any updates on the WSL recently?
Warm regards.
- SHard26 years ago
Good morning
I am using Windows 10 Pro 2004 (Build 19041.450)
I had previously tried using 'New->Nios II Application and BSP from template', this also fails.
On further research this appears to have been caused by a windows update changing wsl1 in some way. I have tried wsl2 but unfortunately, due to another problem with the Intel/Altera 'create-this-app script', this also fails as the script is looking for 'uname' to return 'Microsoft' when it actually returns 'microsoft'.
I cannot update to Q20.1 as Intel have dropped support for DSP Builder for the 'Standard' license release.
I have reverted to Q18.1 Build 646, unfortunately this also fails due to another problem with the Intel/Altera 'create-this-app' script. This time the script fails by breaking the permissions of its destination folder, giving the following error 'Eclipse - Error Creating Project (Access is Denied)'. There does not seem to be a satisfactory solution to this.
I have ended up reverting to Q18.1 Build 625 to find a release where the NIOS II Build Tools actually appear to function correctly.
I am forced to use the Quartus Prime Standard product as Stratix IV is not supported by the 'PRO' product. The Standard product is not free and has a not inconsiderable price attached to it, along with additional charges for the other packages we use. It would appear that all effort seems to be in the 'PRO' product which only seems to cover the very latest devices.
In which case I am struggling to justify the license cost to cover the legacy devices we must continue to support. If this is the Intel policy now I feel that for any new boards I should consider changing over to Xilinx.
Simon
- BoonBengT_Altera6 years ago
Moderator
Hi @SHard2,
Noted with thanks on the details explanation, yes current we do see that there are some isues with updates on WSL.
For NIOS II Build Tools 19.1, here is another recommended workroaund which perhaps you can try and see hope it help:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.htmlAs for access denied error on NIOS II build tool 18.1 build 646, there seems to be another known similar error which the workaround is to used the older version of 18.1 build 625. (https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2020/why-do-i-get-error-when-creating-a-new-project-with-nios-ii-ecli.html)
On the final part mentioning the support of Stratix IV in Quartus Prime Pro, is that the DSP builder that you are referring to? I did mananged to check on the Handbook for DBP Builder, it seems to be supporting Stratix IV. Hence just curious, can you please help me to understand by further eloborating on what are the non supported feature mention?
Warm Regards.
- SHard26 years ago
Hi
I have asked in a previous support request to Intel about support for DSP Builder in 20.1 STD, I was informed that from 20.1 onwards it was no longer supported. This prevents me upgrading beyond Q19.1, as I must support Stratix IV which therefore limits me to the STD product.
Secondly, the work around you mentioned for Q19.1 does not work. Certainly not when I tried it.
The NIOS tools worked correctly in Q19.1, using WSL1, until what I understand was a windows update. After this point the NIOS II toolchain no longer worked, as described in a number of support requests. The workaround you mentioned just clarifies that 19.1 does not work with WSL2.
Simon
