20 years agoNios II and separate WRITE_N signal to CFI Flash
Hi, It has been long time I played with Nios II, my first attempts were abandoned due to the project change. Now I am blessed with another project which would have a Nios II as a CPU candidate and...
20 years ago --- Quote Start --- originally posted by pszemol@Mar 6 2006, 11:15 PM my question is: why "write_n_to_the_flash" signal is not shared with the rest of the write_n signals. in other words, why do i have separate write_n signal instead using mem_bus_readn/mem_bus_writen signals for both sram and flash ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13165)
--- quote end ---
--- Quote End --- The SOPC builder CFI Flash declares the write signal as not shared signal. In fact, if you open the system ptf you should find somethig like: MODULE FLASH { ... PORT_WIRING { ... PORT write_n { width = "1"; is_shared = "0"; direction = "input"; type = "write_n"; } So SOPC Builder generates one write signal for the SRAM (mem_bus_writen - shared bus signal) and one for the FLASH (write_n_to_the_FLASH - not shared). As this is not modifiable in the GUI, you could manually edit the ptf, putting is_shared = "1"; to have a single, shared, write signal. Hope this helps.
