12 years agoNIOS II 32 bit data master -> Avalon MM PCIe 64 bit TX slave
I had a system working where the DMA controller ( 64 bit ) was reading and writing to the TX port of the PCIe TX port . I now have a situation where I want the NIOS II data master ( 32 bit ) to r...
10 years ago --- Quote Start --- Hi all, - I am already having a design that communicates with x86 processor from NIOS II using the shared memory over the PCIe interface. - With new design my aim would be to reverse the shared memory and place it on the x86 processor DDR memory instead of FPGA SSRAM. - And aware of this would require some complex address translation logic to be included in the fabric. - I came to know that, "txs" signal in the PCIe interface ip core will access the host memory, but I want to know how that signal will access DDR memory or some other internal memory on x86 processor. - Also I like to know how DDR memory in x86 processor is used? - I am interested to know if someone has already achieved something similar and if it is possible to get hold of a reference design for this or related configuration to start with. --- Quote End --- Hi Varun, This link will take you to various Altera Reference designs for PCIe. //www.altera.com/products/reference-designs/ip/interface/m-pci-express-refdesigns.html The TXS port is an Avalon MM slave port used to generate Inbound PCIe Read and Write operations to a RC. I am not familiar with "DDR memory in the X86 processor" ... but Host system will have a memory map for Memory / Register space that is accessible from the PCIe RC. I assume you want to get a DMA operation from the EP to the Host DDR memory. Regarding translations, the PCIe IP / Avalon Bridge has local translation tables configurable by the user to be a static translation or configured by NIOS II core. These translations can be 32 bit Avalon MM-> 32 bit PCIe address or 32 bit Avalon MM -> 64 bit PCIe. There are other reference designs like Gen3x8 with DMA that use a 64 bit Avalon MM address -> 64 bit PCIe address without any translation. Best Regards, Bob
